LinkBack Thread Tools
Old 03-10-2010, 01:32 AM   #1 (permalink)
I just got the Cobb access port (a fun little gadget) and i looked at my codes and im getting a P0605 code i cant find any info on what it is i just see ECM/ECU... i couldnt find any more descriptions of what it is...
Borla TD exhaust, Kinetix test pipes, JWT intake, motordyne 5/16 plenum, Hotchkis Stage 1 TVS, Cobb AccessPORT stage 2+.
prsmesa24 is offline   Reply With Quote
Old 03-10-2010, 08:21 AM   #2 (permalink)
SmoothZ's Avatar
http://www.350z-tech.com/zwiki/OBDII_Codes lol...now we need a translator for those descriptions.
April 24, 2009 at 41,424 miles
October 12, 2009 at 43,502 miles
March 19, 2010
SmoothZ is offline   Reply With Quote
Old 03-10-2010, 08:40 AM   #3 (permalink)
westpak's Avatar
it is thinking there is something wrong with the ECU (ECM) most likely due to the acessport, I would call Cobb and get with them, it may be something as simple as clearing the code and your ok or your ECU might need recovery.
Does the car start and run OK? If so then it may just be a momentary code due to the flashing of the ECU and clearing the code is all that is needed.
westpak is offline   Reply With Quote
Old 03-10-2010, 12:52 PM   #4 (permalink)
QUOTE (westpak @ Mar 10 2010, 08:40 AM)
car runs great... i imagine the ECU is working fine because it transfers all information to the accessport like coolant temp intake temp RPMS all info like that. i know ECU does a million things.. but all seems well.
Old 03-10-2010, 02:32 PM   #5 (permalink)
PCM read only memory (ROM) error . I bought a code reader awhile back and that is what that code came up with. Kind of an odd ball code though
Factory Five Cobra Levy Racing Built
Stage 3 Levy racing 347
Baer racing brakes
Four corner coil overs
Halibrand wheels
0 to 60 3.5 sec, 160 MPH Top End.
http://i698.photobucket.com/albums/v...1/Cobra2-1.jpg
2003 350Z-6 spd Chrome Silver Touring
GTM built forged motor, STS Single turbo
Willwood BBK (6 pot & 4 pot) Hotchkis Swaybars
Eibach Pro's & Koni's Probuilt Flywheel & 6 puck clutch
AEM & Autometer gauges 350Z source bumber
BCR harness bar /impact racing 6 point harness
Carbon Fiber TS rear diffuser
Mahadi 19's 245Frnt, 275Rear T1R's (street)
ROTA 18's 265Frnt, 285Rear BFG R1's (Track)
http://i698.photobucket.com/albums/v...eed1/133-1.jpg
jimz350 is offline   Reply With Quote
Old 03-11-2010, 12:00 PM   #6 (permalink)
Send a message via AIM to dadevilz
Would check battery connections make shure grounds are clean that could throw out tha code possibly and sometimes a weak battery. If not have you changed the ECM or done anything to it lately? possible the VIN is not registered in the ECM just ideas too look at if the code is serious
dadevilz is offline   Reply With Quote
Thread Tools
