what sould my oil gauge be reading - Nissan 350Z Forum, Nissan 370Z Tech Forums
post #1 of 8 (permalink) Old 10-22-2007, 11:19 PM Thread Starter
hi, just bought a Z and woundering what the gauge should be reading. also r there different types of cubbyholes because mine seems like there is a screen or something in there. thanx
BurnRubber is offline
post #2 of 8 (permalink) Old 10-23-2007, 11:18 AM
zguyd3's Avatar
At 2500-3000 RPM the oil pressure gauge should read around 60 PSI, but the factory gauge is not all that accurate. Your CEL will come on if you dont have enough pressure.
Congrats on the purchase and welcome to Tech
<div align="center">My Garage
zguyd3 is offline
post #3 of 8 (permalink) Old 10-23-2007, 12:24 PM
I thought the tech manual for the z has the idle oil pressure at about 13-14 PSI...
at cruising speed on highway it should be about 60 PSI.. someone correct me if im wrong.
art_suckz is offline
post #4 of 8 (permalink) Old 10-23-2007, 02:00 PM
zguyd3's Avatar
Thats right Cykick my bad I had that mixed up (been about a week since ive drove the Z). It should run about 60psi at 2500- 3000 rpm in each gear.
I am going to fix my 1st post
zguyd3 is offline
post #5 of 8 (permalink) Old 10-23-2007, 03:25 PM
SlickRick2869's Avatar
Send a message via AIM to SlickRick2869
First of all, to the site, and congrats on the purchase of your Z. Your first question has already been answered correctly so...
I'm assuming the "cubbyhole" you are referring to is the one right below the oil pressure and volt gauges... Depending on the trim level of your Z there was a navigation system that came optional with it from the dealership. If it isn't the nav system then I would assume that whoever had the Z before you added it possibly for an in car pc or a DVD player... If this is the case, it is unnecessary and you should remove it immediately. Upon removal quickly ship it to me for ::cough cough:: disposal...
J/K... if you can't figure it out throw a pic up, I'm sure someone will have seen one before.
2003 SuperBlack Touring "Akira"
Nismo CAI || S2K Antenna || DIY Catch Can || Grounding Wires || PURE Spacer
SlickRick2869 is offline
post #6 of 8 (permalink) Old 10-23-2007, 03:47 PM
Also the oil pressure varies with its temperature. The numbers people quoted above are all for operating temps, not cold temps. When you first start the car and it is idle the pressure may very well be above 60psi. I know mine is, however it drops to ~12psi when it warms up.
m1abrams is offline
post #7 of 8 (permalink) Old 10-23-2007, 04:55 PM Thread Starter
thanks for the replies... found out the the old owner did put a screen in there but its not hooked up maybe ill hooked it up with my eclipes avn5435 if any one has any ideas how to hook it up that would help. my oil gauge goes up and down alot when i start the car it will usually be at 60 but driving it can go down to about 40-45 then back up and even some time to about 70-75.
post #8 of 8 (permalink) Old 10-24-2007, 12:06 AM
az350z's Avatar
Send a message via AIM to az350z Send a message via Yahoo to az350z
When its cold it will be different, usually higher. Once warm, it should be 60psi @ 3k rpms.
az350z is offline
